General  Changing front Shocks
Seb
Norwich, United Kingdom.
How do i get the top bolt undone on the front shocks, the main strut bolt, i can't get a spanner on it as its recessed in the mount and the whole strut turns if use a ratchet on it as i cant hold the flat bit as well. any help would be good as i'm stumped on this one.
Hei.
It´s really easy actually. Remember: CORRECT TOOL IS 1/2 THE WORK. You need a ring spanner with a "lowered" head. Tamtamtaaa!!! Done this a dozen times.
Morten.
do you mean the ring spanners that are at a funny angle, __/ like that, the one i've got doesn't fit, but i'll try getting a new one thats slimmer. the actual ring of the spanner doesn't fit in the hole around the bolt. but its the same size (19mm) as the ratchet that does fit.
