Technical Changing DRL's...
...and this happened:
Bulb popped off the holder whilst refitting (n)
Is the sidelight/DRL housing a sealed unit, or will I be able to get into it?
Any help would be greatly appreciated!
A chopstick with a very sticky bit of tape on the end might be enough to pull the bulb out, if you've got enough access at the back of the headlight unit to poke a chopstick through.
Good idea! Think I will need something more flexible though, so going fishing with a bit of Cat5 cable wrapped in Duck tape!
wow great answers... they will all work but mine is better and permanent :)
I had the same issue (some time in the near future) and found it best to make a hole in the headlight using an diamond tipped industrial drill, job done in 2 minutes.
God speed !
I did that too...
I bought a magnetic telescopic screwdriver thing for 99p. The base of the bulb is magnetic and after bending the screwdriver to a banana-shape and some mild swearing I retrieved the bulb!
On a more serious note, I don't think i'm going to bother fitting them again, as they didn't seem a great fit (and this was proven when it popped out the holder inside the lamp!)
I bought these: http://www.ebay.co.uk/itm/310337678548
which was a mistake anyway as the original items are dual fillament!
I think these are the ones other people have been fitting (a bit dearer at over £35 :eek:)
http://www.ebay.co.uk/itm/PIAA-H366-Mirror-White-Bulbs-Fiat-500-DRL-T20-27-8W-/330604961639
Am I right in thinking the fact the ones I tried to fit today are single fillament should make no difference to the actual fitment?
I did that too...
Bought it from the 99p store?:)
I found that you need quite a bit of force to get the bulb in the holder properly. It should make a definite click.
Polarg make a dual filament bulb with a whiter light than the stock bulbs. An eBay seller in the States sells then for about £10 a pair with p&p.
