General challenge for you Tipo owners!
NW London
Inspired by Dazzo666 modified thread.
I want my Tipo to be as low as this and to site like this on the wheels, none of that I can fit two fists in that wheel arch.
Your challenge:
Find the lowest possible Tipo Lowering Spings and post a link.
Find the wheel combination along with the spings to remove the wheel arch gap without causing ASBO can't bring your mates anywhere cause the wheels rub'ness'.
I'm playing to :) ready set GO!
trans there are many spring many manufacturers in the the country, most could wind you some car sprinfs if you gace them the old ones, car springs are nothing that special.
rich
rich
Yes but are springs which lower the Tipo 60mm or more? Not talking about standard springs Sedi, I want to make my tipo so low it will look like its having sex with the floor.
i had my first ever 1.6 tipo lowered 110mm it was so low speed bumps werent an option!
i got these of a mate i'll find out where he got them from, if i remember they were race springs, i'll find out more tonyt for you
eh??? they need std springs to get the wind diameter, they could make them 2 cm high! helps to know the std compressed length of the springs you have, then they can work out the spring rate of what you may need. If you get really short springs you'll need to strap them in place as the damper extended length with be greater and the spring could fall out on max extension.
rich
