CD multi-changer
CD multi-changer
bartram108
North East
I've just bought a 12-month old Fiat Bravo 1.4 Dynamic and want to know if it's possible to install a cd-changer which I have from my previous car. Radio handbook implies that it can be done but doesn't say how. My last car had a connection already in the boot to wire it up and I'm hoping for something similar in the Fiat
Found this on another site:
Mark I
The cable is already in the boot hanging down from either the left or right hand side under the parcel shelf supports. Unwrap it from the grey foam and plug the DIN connector into your GRUNDIG CD Changer (there is a hint there on which one to buy!). Screw, stick, bolt or blue tack the unit somewhere in the boot and that is really about it. How you mount it is really up to you and your use of the car.
Mark II
The MK2 does not have a cable installed. If you have bought the changer kit then you will have everything you need. First, decide where you want to mount the changer, they will fit under the rear seat if you want to cut a flap in the carpet, or in the boot if you want to spend the time getting the cable there!
Dave.​
