AndrewRL
OK. So I'm after a bit more education ahead of giving the carb a bit of a service. I've looked everywhere on the forum and in manuals but not found (yet) the answer.
I understand the idle speed adjuster and the instructions to adjust this down until the generator light is just on. But how do I know if the mixture screw is correctly adjusted? What is the proper way to set up the carburettor - which of two do you adjust first and what are you looking for when adjusting the mixture? The workshop manual just says "set to the most suitable ratio"
Carburettor is the standard Weber 26 for 500cc (I think)
More questions to come when I start on this, I am sure
Thanks, as always, for the advice and education
BTW Part of the reason for servicing/cleaning the carb is to try and stop the car cutting out when coming to a stop. From other threads I understand that this is worth trying as well as checking the tappets so that will be next on the list!
