rgberkhout
Hi to all, I own a 2007 (140k km) Bravo 1.4 t-jet, last year the driver side support arm is changed due to wear out of the ball joint. In Februari my car started shaking around 85 km/h Usually 4th gear but is also notable in other gears (higher RPN but same shacking). When I loose the throttle it's gone.
Yesterday the car went to the garage and they found out that the rubber in the back was worn-out, they changed it free of charge (for now) as it is warranty.
Today I Aligned the car to it;s proper values and took it for a test drive. At around 85 km/h there is still the shacking especially when I drive upwards although it's far less violent.
There is in the steering rod more then 1 mm of slack on both sides, could that be the cause of shacking and the rubber wearing out or should I look further.
The most possible scenarios for me are:
*slack in stearing rod
*faulty weal bearer
*Faulty disk breaks
*oblique drive shaft
*engine support bearings/rubbers (*edited)
What do you guys think, I do not want to change the support arm again next year..
Furthermore I love my car
*faulty weal bearer
*Faulty disk breaks
