Technical  Car Fan
Technical  Car Fan
Cobbjo
My fan in car only works on high Speed/ Demist symbol on switch. Sometime it does however work. any ideas of how to rectify this. Also would like to remove the bottom console with the fan switches etc. is it a big job.Regards
John
This is likely the resistor pack, you will need to replace it.
This video shows where it is.
check the wires to it, the connectors (remove them - check they are not burnt out).
Remove the resistor pack, you may need to replace it -they are available online.
Coincidentally, I am now getting this problem too - I need to remove and repair my resistor pack :(
I'm glad someone linked a video for it, im gonna find that useful :)
There are actually 2 platsic bits that needed holding while the resistor pack is slid length ways to be able to pull it out.
Turns out I just needed to plug in, out, in, out, (shake it all about) the plug as it was a dodgy connection. mine works now.
