Capacitor Needed..?
Capacitor Needed..?
Birmingham
Basically ive got my two subs installed now with my amp, however when I try and have my air con it turns the head unit off because both are trying to draw too much power.
So ideally i reckon i will need a capacitor, do i need to look for a specific one or will any one do? i dont really want to spend too much i just want something to do the job
Is that 800w RMS. Even if it is you aren't drawing that much power. I would suggest that there is a problem somewhere. Maybe loose connection on the battery? That would cause issues. Have you tried a different head unit.
Thinking about it more. They havnt connected the HU to the zircon for some reason? If it is a legit place then I'm sure they will be more than willing to help you find the problem. Where was it? You never know I could know them.
In the mean time trying the other unit would be a good idea.
can i connect the zircon myself or is it too much effort? and i got it installed at a place called rs fleet. also if i install the new head unit is it simple enough to make the head unit turn off with the ignition?
