Technical Cant find the heat resistor...????
colinv
who van help me finf the heat resistor on my stilo
i got a 1.6 Mw from 03 and its a LHD
a already had teglove compardmet removed ect butt still nothing to see
i need to replace in because my climate control only works on his slowest speed..
please help im freezing
ps; some pics would be great
ps:2 sorry for my bad english
Is it climate control you have with the adjustable display and not the dial type air con, if it is climate control then you will not have a resistor as the climate control heater fan has a circuit board built into the heater fan, more than likely you will need to replace the heater fan I had a similar problem with mine, replaced fan which fixed it, the fan for UK right hand drive is down in the foot well and is changeable but awkward yours may be easier if it is left hand drive.
Found 6 pages of info on climate fan in link below
https://www.fiatforum.com/stilo/90245-climate-control-faulty-fan-6.html
thanx will check it tomorrow
waiting for my new fan to arrivé.
i will place it in my car asap and will let you guys know if the problem is solved .
i'll try to make some pics of it in cade someone els needs it in the futere
Got my new fan installed yesterday.
It works 100% and that only for €75,- and 45 main work... Will post some pics later.
as promised the pics I made
these are how that I removed the fan.
replacing it its just the same way but backwards
hope it helps some one who needs to change it as well
