I've had an issue with my GP for a while.
The odo has been flashing as long as I've had the car; first attempts at a proxi allignment failed due to the common isue with cheap ELM cables having incorrect resistors fitted, but I've a new one on the way.
My passenger window stopped working a while ago; it'd go down but not up. I noticed on MES that the CANBUS has a node in the passenger door. Could the issue be CAN related, or is it more likely to be a failed wiring loom? I also have a new loom on order, but I'd hate to go ripping the old one out if a simple proxi allignment would fix it! At present the plug on the window motor is disconnected!
