JayC
As above. I need to change the steering column, not because the EPAS has packed in, but because the knuckle at the bottom of the column has a load of play in it.
Could I theoretically unplug the ECU from my existing setup and plug it into the replacement, without then having to worry about it not being the right code for the car?? As I seem to be understanding it, you need a PAS unit with the same code as the one you've got on your current one if you plan to swap them out??
