Technical Can You Help Me Identify These Parts
stevenk9958
Yucca Valley, CA
These three parts were included with the purchase of my 1978 Fiat 124 Spider 1800. I don't know what they are or where they go in my engine. Can you help identify them and their location? Thanks in advance.
Model
124 Spider Convertible - 1800
1978
It does look like pollution control stuff someone took off to make the car run better, and saved the pieces for the next owner...my 79 was a California smog car but your parts don't resemble the parts removed from my car...the part held in your hand is possibly related to the top of the head...I've never see the part with what looks to be a "tank" with the 2 vacuum/ electric solenoids....I would recommend getting a copy of the big yellow Pininfarina shop manual from ebay, there's a whole section on the exaust and emission control systems with illustrations....it's a book you should have anyway if your restoring you spider 😀
The first is an EGR valve and the second third and 4th picture are all to do with exhaust gas recirculation. No idea what the last one is have you any more angles ?
The parts are afaik an EGR valve and pipe, an air injection possibly check? valve and hose and a control unit with 2 electro-valves (see pic below)
1) To possibly help to identify some of your emissions related parts. (the fuel vapor charcoal canister you asked about in an earlier thread is shown here also, afaik this canister is fitted to the left of the radiator, inside the engine bay, when looking from the driver's seat).
2) A pic I found on the i/net showing the engine bay of a 124 Spider that still has the emissions equipment fitted, might help you see where some of your mystery parts fit and how they are oriented in relation to the engine. As far as I can see the control unit is fitted midway on the left inner fender
3) There's a few pages (p341-p347) on the 124 Spider emissions equipment in this original Fiat Service Manual that you can view starting here:-
4) Iirc, you said you recently got a Haynes Manual for the 124 Spider? I don't have one for the Spider but I do have one for the 124 Coupe up to 1977- at the back of which there is a supplement that gives some information and schematics on the emissions equipment that was fitted to the later cars e.g. EGR., Air Injection, catalytic converter, plus testing the air diverter valve, check valve and air pump.
Thank you very much for your help 124BC1. I spoke to my local smog station close to where I live and they said that if my 78 does not have the original smog equipment installed it will fail. Assuming that these three pieces are original to the car I'm going to have to install them to pass.
I wonder what they mean by " installed"...in other words if they only visually look for the parts/ equipment, or if not having them , and having them functional will cause them to fail the "sniff" test?in other words I wonder if you can just temporarily bolt them on for looks to pass and remove them when you get home? Does your car still have the air pump normally on the passenger side of the block? I'm assuming your car came with one as my California spider did, and if you do, is it still hooked up by belt to the crank pulley? I'm glad my state eliminated emissions testing, as old as our cars are they should get a free pass, and i question even if the parts were hooked back up at this point in time, if it would even make a difference in emissions? Anyway I feel for you and hope everything works out...
The air pump was off the car when I got it, and I restored the finish, found some bolts to install it to the car and bought a new v-belt which I was able to hook up to the crank pulley. Do you know where the other end of the hose attached to the air pump goes?
Here's a sketch that shows #12 air pump going directly in to a diverter valve#13, this sketch pertains to non catalytic systems, not sure if it's the same as yours...my 79 has a converter but the air pump was long gone when I got the car..
This pic shows the air manifold for 1975 to 1978.these illustrations may or may not resemble your car? You need a sketch of your exact system to be sure.
The EGR valve and metal pipe connects from the exhaust manifold (header) to somewhere on the intake manifold below the carb.
In an earlier thread you showed a picture of what someone identified as a 'heat shield'.
In this heat shield there is a large hole, through which the EGR metal pipe usually screws into either a threaded hole in the exhaust manifold or into a threaded hole in a plate that is attached to the manifold by 2 bolts. (the previous owner could have blanked off this threaded hole when he removed the EGR)
What I've identified as an EGR valve and pipe in a previous post
I believe should connect to the exhaust manifold via the threaded fixing on the metal pipe end - similar to what is shown in this picture :-
What I've identified as an 'air injection check valve and hose'
should connect to the air injection manifold on the cylinder head - this manifold is a metal pipe with 4 smaller metal pipes that connect to drillings in the cylinder head leading to the exhaust ports. This manifold afaik is situated between the spark plugs and the exhaust cam box i.e. in the space between the 2 cam boxes on the cylinder head. I suspect that the threaded fitting on the check valve should screw into the air injection manifold. If it does fit in this way, will the hose end reach the outlet on the air pump? Although you seem to be missing the 'diverter valve' and the diagram shows the diverter valve fits between the air pump and the check valve i.e. the order is air pump>diverter valve>check valve>injection manifold on cyl. head.
But as @Slotman has suggested, there were different emissions/anti-pollution equipment used on different years of the 124 Spider so it's important to follow the correct diagram and use the correct pics for your exact model/year of car. Be aware also that the diagrams/schematics that Fiat used in their manuals don't accurately reflect what the individual components look like in real life nor their exact locations relative to other components (e.g. pipes/hoses can be longer or shorter that shown), so these schematics are only a guide or perhaps were used as a teaching aid in their training courses.
I'm repeating the pic of under the hood of a 124 Spider with arrows to try to clarify the above suggestions:-
Blue arrows indicate the EGR valve and metal pipe connected to the exhaust manifold
Green arrow shows where the air injection check valve is attached to the air injection manifold on the cylinder head
Yellow arrow shows a cap/cover on the hot air take-off on the exhaust manifold heat shield - disregard this, it's not stock, presumably someone fitted it when the stock air cleaner unit (which usually has a hot air pick-up connection pipe to the exhaust manifold) was removed to fit a 'sporty' air filter.
I'm finding it difficult to try to advise you when I can't see what you have on your engine e.g. there were at least 4 different styles of exhaust manifold used on the 124 Spider, some had 2 outlet pipes, other only 1, some had the EGR connection on top, others had it semi-concealed under the manifold etc. some cars had catalytic converters, others didn't, (afaik, the cars with catalytic converters all had 2 red warning lights on the centre dashboard panel - 1 light indicated the cat. was overheating, the other possibly indicated the cat. had to be replaced - they had a finite lifespan, or maybe one of these red lights was indicating that the EGR system needed to be serviced, I can't recall for sure).
In order to try to help you any further, could you post pics of the following - exhaust manifold, intake manifold, base of carb and any vacuum connection ports, top of cylinder head showing between the cam boxes, any unconnected pipes/hoses around engine or elsewhere in engine bay, any unconnected units plus any other possible emissions- related parts that came with the car - I'm not seeing e.g. the air diverter valve or some of the EGR pipework.
Thank you for all the information, it helped a lot. I'm down to just these two parts provided by the seller to re-install in my 1978 Fiat 124 Sport 1800. Do you recognize either of these parts and know where they get installed?
The part on the left appears to be the Diverter Valve, the part on the right appears to be an Electrovalve, see items 13 and 21 in the schematic helpfully provided by @Slotman in post #9 above - as can be seen, the diverter Valve is installed somewhere between the Air Pump and the Check Valve and the Electrovalve pipes are connected 'across' the Diverter Valve.
Before submitting your car for a 'smog' test, might I suggest that you check the newly re-installed smog gear is actually now working correctly. As I mentioned previously , there may be info in your Haynes Manual on how to check if the air pump, diverter valve and check valve are working correctly.
I would also try to check all the electrovalves are working - it may be that one or more of them might be sticking due to inactivity, you might e.g. try applying battery power across the terminals and check if you can hear or feel the internal valve working or maybe try blowing some air through with the valve powered on and then powered off, there appears to be a little button on top of each electrovalve - this might be a test button that you can press to check if the valve is working?
P.S. Did you succeed in fitting the gas door spring mentioned in another of your threads?
I have cables that I previously made that connect from my battery terminals to test ends that I can touch to the terminals to test as you suggested. I bought the pinafarina manual off eBay and found the diagram that slotman posted on #9 so I have the wiring to follow.
If anyone has pictures of these two components so I can see where they get installed in the engine bay, please attach pictures to this post.
As to the spring for the gas cap, I found a video on YouTube of someone installing the spring. I followed those directions and re-installed my spring just like in the video and the gas cap still didn't work right for me. I'm going to see if I can rig up something else that works.
