Technical Can I get elm327 advice that I can connect to the body?
nahita1923
Hello, I have a Fiat linea 2013 model 1.3 multijet euro5 engine. I'm thinking of picking up some features on the Fiatecuscan and picking up the elm327 device to read and erase the fault codes. In addition to reading, these devices need to have a PIC18F25K80 chip to be able to connect and write to the body. Have you ever had the Write function working next to the reading that used this chip? There are too many fake in the market. I would appreciate if you share your experiences on this subject.
I use wifi elm327.
Had to remove the r04 (121) resistor. (check pictures)
I can read/write body computer without problems. (y)
I use wifi elm327.
Thanks for the answer. Where can you share your product link? What's the brand of it?
hmm it's a classic elm wifi module from ebay (fake/clone chip probably).
I have the old 1.4 version (year 2012)
https://www.ebay.com/itm/ELM327-OBD...h=item4b2c0566d2:g:u2sAAOSw5VtZ-4Ez:rk:6:pf:0
I got it years ago and it's still ok. Some clone usb modules had problems with latest drivers but wifi is fine. You need to remove the resistor though.
Keep in mind you need to buy the YELLOW cable adapter to connect to body computer.
