Technical  cam sprocket slipped
ulysse121
replaced cam belt and rockers after it snapped but noticed terrible lack of power, it seems sprockets have slipped on cams but there are no two markings that I am able to use to re-align, car has been off road now for 10 weeks, any help greatly appreciated.:confused::confused:
thanks
Have you checked the locating pin on the pulley ?
Sometimes it brakes with the cambelt but since you have it running it should be alright.
Did you released the 3 bolts on the pulley while timing the belt?
Move the engine to top dead center, put the locating pins (I used 2 8mm bolts) on the pulley and crank (flywheel)
They have to match if they don't lock the crank, release the 3 bolts on the pulley and move the cam so you can fit the pin on the locating slot/hole, then just tighten the 3 bolts and you should be back with full power.
On rebuild or cambelt change the 3 bolts have to be released to allow correct timing of the belt.
Good luck
Ric
thanks for that it's now sorted!! yippee!!!
apparently also the vacuum to the turbo was faulty, now goes as it should.
many thanks again.
