My advice would be to try if you can to stretch your budget so you are not getting the cheapest Coupé out there as it's likely to be a dog and could cost you more to fix than you paid to buy it. They are cheap for a reason and there are some real sh*tters out there. At the end of the day they are/were a £20k 'performance/sports' Coupé when new and I know they depreciate, but you are unlikely to pick one up for absolute bobbins.
As Pinin said £2.5k should get you a decent-ish 16v non-turbo, but £3k would get you a nice one. Like he said, look at a few before buying, take the buyers guide on the Coupé forum along with you and all the usual - cambelt should have been done by 72k or 6 years and then every 36k after (I think
) - if it needs doing, budget at least £400 (what some specialists charge) for that, but try and knock them down around £800 (the minimum I've seen FIAT dealers charge). FSH, red key etc. also important - check the condition of the clutch (new one is about £400 fitted at a specialist), wishbones likely to go around 50k.
Look at the exhaust, especially the tip. If its an original OE FIAT one, the chrome tip is only spot welded to the pipe and can fall off, the heat from the gases can then melt the bumper around it.
If it is a private sale, ask the owner about what oil they use/how much the car uses/how often they check (at least once every 1000 miles on a n/a) - this should give you an idea of how much they care for the car.
Generally the non-turbo engines are pretty reliable and there are plenty of 16v cars on the Coupé forum with well over 100k miles.
Of course, if you can stretch to £5k and want a nice late 20v car - I'll be selling mine within the next month
(99T, red, black leather, 53k, cambelt, brakes, exhaust, wishbones all done within the past 9 months).
