Technical Butt warmer
Brava GT
Brava´s buttwarmer seems to be broken and was wondering if anyone knows if fixing it requires replacing the whole seat or just the upholstery...?
Italiana
Should be able to just be the elelment, which is bonded to foam. I think it comes with the foam. Is the red light on the side of the seat comeing on if so it will be the element, if not check connections under seat for coming apart.
<blockquote id="quote"> face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by FiatExpert
Should be able to just be the elelment, which is bonded to foam. I think it comes with the foam. Is the red light on the side of the seat comeing on if so it will be the element, if not check connections under seat for coming apart.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Roger that, need to check the signal light asap, thanx :)
Italiana
