Technical Burning out the Alternator
Carrickfergus
We have picked up an 87 1000 CL and it burned the Alternator out. Stuck a new one in and it did the same in a few minutes. Also the Fuel & Temp gauge go to max the minute you turn the ignition on. Any ideas?
it sounds like the main earth cable has shot it. everything is trying to earth the shell to the engine..
though for an alternator to burn out, that does require a direct short to ground... hmmmm
do the jump lead trick.. one going from battery negative to shell, then one going to the shell to the engine.
