I can see a problem if the vehicle is propelled up to say 50mph and the clutch is dropped in second gear.......you would expect a degree of mechanical protest and possible damage. However a typical bump start is carried out at low speeds of say < 10mph (because someone is pushing). If the clutch is engaged briefly at this speed, just enough to rotate the engine, and isdepressed immediately after it starts I would expect the chace of damage to be very low, bordering on the non existant.
