Technical Bulb failure....stop light message
Barnsley, South Yorkshire
Hi
Today and yesterday i got a 'Bulb failure....stop light' message and an arrow pointing to the left (passenger side). It beeps at me and goes out after a few seconds. I presume this means brake light? However all brake lights are working fine. What could be the problem? I've only just sorted my complicated power loss issue, its one problem after another!
Phil
Well I thought I would try and clean the contacts more aggressively. I used some paint rubbing paste on a cotton bud and rubbed the pins on the cluster. Cleaned it with some contact cleaner on another bud. I also noted the pins on the cluster had lost their tension slightly on the earth pin so I used the multimeter probe to move them closer together. Have taken for a run and it didn't squeal at me, so fingers crossed...
Poor old bulbs always get the blame! Take a look at the relay if I were you. Swap it for another in the relay box of equal size and test.
