broken headlamp bracket
doost
i'm right to assume that you just can't fix a broken plastic bracket that holds the headlamp in place on a bravo - once those things go, they're gone, right? right? And before you ask the other one's gone already.
try "welding" it with a hot soldering iron.
melt the two halves of the crack together and swirl the plastic to "mix" both sides of the join.
bit of fibre glass over the finished repair and it should be strong enough.
go for some good ol 2000psi epoxy resin :D that will do the trick
S
1
797
Dark Lurker
752
Dark Lurker
B
1
374
M
L
1
340
L
S
17
428
N
