Dr Zoidberg
- Joined
- Jul 13, 2008
- Messages
- 334
- Points
- 62
Over the last couple of days the temperature has dropped noticably - it's now about 2 degrees when I go to work instead of 7 or 8 last week. Straight away I've seen that it takes a lot longer for the car to get up to it's normal operating temperature - I can do 15 miles before the gauge gets to it's normal straight-up position and if you stop at a junction for more than about 15 seconds you can see it start to drop again. As a side effect, the fuel consumption is also noticably worse - down 10% on the week before for the same journey.
I saw this behaviour last winter, but only really noticed it when we had weeks of sub zero temperatures and it's not that cold yet.
I'm well aware that diesel's can take a while to warm up, but does this happen on anyone else's car or do I have a problem with the thermostat?
