Technical  Bravo 2013 Electrical Issue
Kells
I have a 2013 Fiat Bravo, 1.6 diesel multijet engine.
Randomly the radio will flicker on and off, then the warning lights come on the dash, then the power can cut and wheel tighten. Or when it happens as I put the car in reverse the power cuts briefly.
I have changed the battery and it does not seem to have fixed this random issue. It happens without warning and if anyone has any suggestions its greatly appreciated. The car is serviced regularly and spotless. I have purchased second hand and it only showed up about 6 months into ownership.
A mechanic said potential live wire somewhere.. as after he changed the battery and it didn't fix it. But said finding that is like a needle in a hay stack.
Thank you for any helpful advice.
Hi Varesecrazy,
Has this solved the issue for you as well?
So just to clarify run a second negative cable onto the chassis. So two all together.
