Technical Bravo 2011 2.0 mjet rpm idle problems
robertzd
Greetings.
First i apologize for my english ( it's not my native language)
I own the car last 3 months. It has 140 thousand km,it is orderly serviced.
The car goes ok, it dont smoke (black) from exsaust,consumption is about 7l/100 km,i think there is no problems with engine. I'l tray to explain my problem and hope someone will have the answer. At this 3 months i noticed this anomaly 9-10 times. I'm driving car normaly,park infront of house (or stop at red light) manual gearbox in that moment in neutral and my idle rpm start vary. It goes up and down about 200 rpm and sometimes is present sound of detonation in engine, like not good mixture of fuel, tuk tuk sound and i felt vibration of car. When i'm infront of house i turn off car and turn on and it's all normal. If i'm on the red light i keep on and after few minutes if i stop on next red light it's all normal. The problem is that board computer dont show any error. I exclude gas problems becouse i changed couple gas pumps and it's the same. It has been on 2 diagnostics and 0 errors, all pipes are inspected for air leakage.I'm traying to collect as much data i can to localize problem. Last 2 times it happend i remember i was open road driving,distance 15-20 km and outside temperature is low 7 ' C (winter time ). When i park,the rpm vary and the car radiator fan vas working full speed , like in summer,when you stuck in traffic. But the car temperature on gauge is always normal,it raises it good and it hold it on middle. Is this two connected maybe ? why does the radiator fan swith in winter, (AC was switched off ). Any help is appreciated . Thanks :)
Hi, i have the same car as you, this is normal, it is the DPF regenerating.
In this time i own the car i only once see the message on board computer DPF cleaning please keep car running. Should he write that message every time when he do it?
My car has never displayed that message
My did that one time,i put key into ignition and he show that message,while i was driving message dissapear.
Could you tell does youre rpm just increse for 100-200 or they also vary up and down like mine?
Now i read about regeneration and mostly say it just increse up rpm.
It jumps from about 800rpm up to 1200rpm then repeats.
I'm happy to hear it work like yours then. Can i ask how you find out it's dpf regeneration. I asked two mechanics and nobody even mention dpf as possible couse. I would like to know more, how often it happens,how long it last? I read that dpf cleaning cyclus is stored in ecu? Is it posible to see dates maybe to see how often is he regenerating? I understand every car brand is different and i think they should make some manuals about it for ppl who react at every strange sound in their cars :)
