Bravo  Bravo 1.9 multi jet diesel
Phelps187
Temp gauge rising to H, all coolant levels ok heaters on blowing cold air?
Hi. Possibly got an issue of coolant not circulating..
With engine showing HOT. TURN OFF ENGINE
lift bonnet. And CAREFULLY check coolant hoses for difference of temperature - beware the rad. cooling fan could cut in ..!!
Could be due to waterpump failure..or an airlock - either could stop the flow of coolant,
Let us know what you find
Charlie. Oxford
Charlie. Oxford
Or thermostat
If not warm inside the car there is a fault waterpump or blocked interior heating radiator.
When the thermostat is stuck you have very much warm inside cabin.
