zoltanpapp82
- Joined
- Jan 17, 2016
- Messages
- 27
- Points
- 61
Hello,
I bought a 1.4 natural aspiration petrol engined Bravo, made in 2008, so an early version. Altough it is not a muscle car is very convinient to drive. I have no issues with it only the idling drives me crazy. I monitored some values with Fiat ECU Scan, so values are based on that:
First start every morning the idle speed starts at 750, throttle is about 6%, of course engine shakes quite well. And after 2..4 seconds the idle rises to ~1300 and stays there for a while than lowers to 750 as the engine is getting warmer. On cold start the expected idle speed is ~1300 but stays 750 for some seconds, I do not know why. When I step on the gas it rises immediately, so if I start the engine with gently stepping to the gas the symptom can be hided.
Is it normal? No fault code is present, no poor gas reaction, just tricky start after longer whiles.
The other is the idle speed "flatness". Throttle position varies continuously a couple tenth percent which makes idle speed variation like 20..30 RPM. I read somewhere that 30RPM variation is just normal, but I never seen such a symptom on my cars, neither on my MKII Panda (ok, it has a separate idle motor) nor on the 1.6 Astra. I can hear the variation which sounds worse (faster variation) when load is engaged, like high beam, air conditioning.
Is it normal? Mechanic says he cleaned the throttle valve with cleaner. Shall I disassemble and clean it thoroughly?
The car just had a new battery and new filters, spark plugs, engine oil, coolant...
Thank you,
Zoltan
Thank you,
Zoltan
