S
Stuart
The engine on my 1.6 died at a roundabout a week back. I got it started but it wouldn't idle so I ordered a new idle valve from Fiat. Fitted it tonight but still no joy. The car misfires when it's first started and won't idle on it's own even when warm. It doesn't run too badly once it's on the move but idling at 3000rpm gets you noticed at the lights
I measured all the sensors with a DVM probing through the connector at the ECU and they all give the kind of readings you'd expect apart from the Lambda sensor - heater wires read low resistance (OK I think) and sense wires read open circuit (not sure about this).
Any ideas? Is the Fiat diagnostic likely to find the problem?
Stuart
Stuart
