brava will not start
S
steve
Hello can anybody help,i have a 1.6 brava which will turn over fine but will not start,there is a good spark ,fuel pump works ok however there is no fuel reaching plugs,have tried fuel inertia switch is ok,any ideas anyone?
regards steve
how do you know theres a good spark?
Buzz
The champion of the Bravo 1.4
& now ex owner of a Bravo 1.8
when i had a similar problem it was the fuel pressure regulator had packed up.
Try changing that
Stu
If engine is turning over OK then battery and starter motor are fine, meaning crank sensor is by far the most likely problem (no spark on all plugs = faulty crank sensor).
If engine is not turning then battery is flat or starter motor is faulty. If battery is flat it could be due to a bad battery, or a constant drain, or a faulty alternator not charging the battery.
I thought my battery was ok, until I needed a jumpstart on 3 occasions in a week. She would turn over quite well but would not start.
New battery and she starts on the button every time.
Dont automatically assume the battery is ok if its turning over. It could well be that its not turning fast enough
7K
David Slaney
3
7K
Steve
S
J
956
jason
J
879
David
G
2
910
T
