Hi all,
I've just attemped a simple replacement of the 3rd (led) brake light strip in my Brava, and it's caused a bit of hassle.
Firstly I had difficulty removing the rear cover panel on the bootlid... took the screws off and forced the top of the panel upwards / forwards.. I thought it was just clipped in tight at the edge until I cracked the cover and snapped 2 hidden clips..:bang: There are 2 secret Allen bolts under the rubber cushions..
No mention of them in the Bravo guide here..
http://www.fiatboo.co.uk/fix-a-bravo.htm#wiper
Also I've managed to lose one of the 3 funny big plastic nuts that hold on the brake light.. it dropped into the bootlid frame (I think) when i undid it and I'm damned if I can find it it inside the bootlid, on the boot floor, on the ground...
But my main question is the wash / wipe hose... there was a stray pipe (starts off black in the top left of the bootlid and then goes to a clear section (full of dirt) with a little black 90 degree connector on the end. However I can find absolutely nowhere on the wiper assembly that it might connect to. There is lots of info for Bravos saying that these fall off and how you can reconnect them, but maybe the Brava is slightly different. The photos in the guide above don't look the same.
Does anyone have any ideas or experience? I took the wiper unit right off but couldn't see anything obvious.
cheers
John
cheers
John
