brava problems
brava problems
david
i have a number of problems on my W reg brava and need solutions please,
1) since the wiring plug for the lighting moved away from its contacts on the fuse board my 3rd brake light works when it wants to.
2) my rear washer jet doesn't even dribble, you can smell screen wash in the car though, where does the hose run to the back of the car?
3) where is the rear wiper relay because sometimes i can hear a relay and when this happens my rear wiper wipes really slow clicking in the back.
4) is it possible to reset the airbag light myself, as when i was checking to find out why my back lights didn't work i must have pulled the fuse out as all my fuses are unmarked?
Re: Re: brava problems
thanks, i've had a look but it still don't have anything about my air bag light and it don't tell me where the washer pipe runs
Washing Bag
The bravo guide definently tells you where the washer pipe issue is most likely to be.
http://www.bravo-guide.co.uk/fix-a-bravo
about 3/4 of the way down.
As for the air bag light, that probably requires a re-set by the dealers, there is not a lot you can do on that one.
Nige
Re: Re: Washing Bag
? it requires a re-set buy the dealer as per the second paragraph of the post ?
1,2&3 are all connected
You see the pipe for the rear washer has come unstuck from the surround to the rear wiper. This happens when you don't use anti freeze. It's easy to glue it back in place but the rear trim has to be removed.
When you get it off you'll find the water has been running into the third brake light and all the terminals are corroded.
Thirdly, any water still piddling out will fill the space around the wiper spindle which corrodes and is then hard to turn.
Perhaps somebody wants to put this on the 'fixit' page.
I
2
1K
Dark Lurker
7K
David Slaney
J
984
jason
J
G
2
930
T
758
Dark Lurker
