Technical  Brava lights
martinsbrava
Hi everyone I have a 2001 Brava and the following lights fail to work glovebox light boot light and the the brake light on the boot any tips
Glovebox light, dont have one on Brava, should be same as on Marea, remove glovebox and see that the plug is attached (and the bulb is intact).
Boot light, dont have one so hard to say, boot switch?.
Brakelight, if it is original, the bulbs might be okay, but the whole bulb assembly is pressfit and has corroded the leads off the bulbs.
Diassembled and replaced mine with normal 5mm white leds.
Or the contacts on the boot are bad, but my money is on corrosion damage.
Thanks I shall have a look at that tomorrow do you know were the switch is for the boot light
Thankyou so much it was the switch and the bulb was put in the wrong way and I got glovebox light sorted that was the bulb being the wrong way to thanks for you help
