Brake fluid or pads?
Thanks for all your advice. I still have some questions, however.
I've been to a Kwikfit nearby, and they looked at the brakes. They also tested the brake fluid. The front and rear brakes were far within tolerances, and my brakefluid seems to have been changed just before I bought the car (seven months ago), cause the level of water in the brakefluid was near 0.
Looking at this forum, it seems no one has had brake troubles. Perhaps the dealership used dot 3 instead of dot 4? How can I check this? If this is not the case, will dot 5 help?
I must say, even though the stopping power is greatly reduced, the pedal stays (nearly) as hard as with cold brakes.
A local autoshop offers EBC greenstuff pads for my Bravo. Will this help against fading?
Also, is a brake conversion to discs in the rear possible?
Could be I'm just spoiled, having had a peugeot 605, with four-pot calipers in front and vented discs in the rear.
Alex.
