Technical Brake servo advice.........
I don't think that is it:confused:
I'm looking for the vacuum pipe on the brake servo so anyone know for sure?
HI.
Ok I'm a newbie here but will try to help.
Not sure if you fund it yet. UK model. Looking at the oil filler cap look past that and slightly to left you'll see a silver/aluminium brake master cylinder with thin pipes coming of it behind that you'll see a black round servo unit the servo pipe is towards bottom right side, usally connected to white plastic the pipe is about the size of the garden spray hose. Greg
Because diesel engines don't develop an induction vacuum in the way a petrol car does, if you're having vacuum/servo probs, it may be the engine-driven vacuum pump is faulty. Follow that tube you've found round to the front left corner of the engine block (you'll need to remove the big plastic cover), where it goes into the pump that's sitting on the side of the block. Check the connections to that -- mine, the clip had come loose
Pete
