General  Brake Pipe
General  Brake Pipe
Ttalor66123
Tetbury
Hi all just had M.O.T done on my 2001 fiat ducato passed all ok.But on the way home a deer jumped out in front of me making me brake really hard afterwards i felt the brake were bit a spongy been underneath and have a leak on the near side front wheel which i think goes to the A.B.S Do any of you guys know where i might be able to get one
Heres hoping many thanks Jack Its a 2.8 jtd tag axle
I have just been looking at an x244 diagram which showed the ABS in that location.
For a complete part Coastal Motorhomes supply parts for older vehicles. Alternatives are getting one made to pattern, or DIY, which if you buy a flaring tool, requires minimal workshop facilities.
Try not to get air into the ABS pump, or you may need extra equipment to bleed it.
Many thanks for your reply.Called coastal no joy they also said make your own.Would you be able to send me the diagram it would be great if you could
The diagram that I was looking at was a location diagram for electrical components, so I doubt that it would help with brake pipe replacement.
For DIY you will need as stated a brake pipe flaring tool. A brake pipe bender will help make a neater job. I suggest cupro nickel tubing. You will also need the correct fittings unless re-using the old ones which may be possible. A good car accessory shop should be able to supply these items.
Your a star Many thanks
(y)(y)(y) Have a great weekend
Thanks.
Another tip when working on hydraulic systems, is to fill the reservoir to the brim, and then secure a piece of thin plastic over the top. This helps to reduce fluid loss. when pipes are disconnected.
