When I run ECU scanner it tells me my brake pedal is depressed - however the brake lights are working normally. Any idea where to look for the problem.
if they are working ok and car runs ok ignore it,
if you press brake does it show not pressed ?
some of the ecu scanners do not support all functions and have bugs this maybe just one of them also depends on your scanner. just cos it says genuine on the outside dont mean its not a chinese copy on the inside
