Technical  Brake lights not working
Oxford
Someone tapped on my window today and pointed out that the brake lights on my 52 reg Multi aren't working.
I checked, and none of them are working, but the indicators and everything else on fuse 13 is fine. I did a bit of hunting on this forum, and everything pointed to the switch, so I took it out, took it apart, cleaned the contacts (there was quite a lot of black gunge inside) and put it back together again. And it still doesn't work. :mad:
Is there anything else I should check (should I jumper the connections in case the switch is just buggered)? I need to use the car to travel > 100 miles tomorrow, so it would be kinda useful to have working brake lights!
Duncan
PS it passed 250,000 miles last week, so I guess I should expect things to break occasionally, but it really is bad timing!
Duncan
Quick check is to pull the connector off the switch and put a jumper wire across it. If the brake lights come on the switch is faulty.
Robert G8RPI.
Thanks Robert. I jumpered it, and it didn't light up the drivers side brake light, but the other 2 came on! So I guess I've got a bad bulb and a bad switch!
I put the DVM across the switch and the resistance doesn't change when you press the button, so I guess the switch is dodgy. I'll take it apart and see if I can make it work on the DVM - if not then I'll have to find a new switch tomorrow morning.
Duncan
Well done. Isn't there a great sense of achievement whwn you fix something, especially when the "experts" say it's not a fixable part! Repaor is better than replace and recycle
Robert G8RPI
