brake light sensor
brake light sensor
P
paul
can anyone help? My brake light sensor comes on intermitently,I've changed the bulb but it still comes on! the rear light works now and again,more often not though!
Re: Re: brake light sensor
its the white plastic switch, this is for a punto, but your car should have the same type of arrangement.
Re: Re: Re: brake light sensor
i've just re-read your post, do you mean your brake lights flicker?
Re: Re: Re: Re: brake light sensor
I think its the same on the bravo.
Get your head under the dash and have a peek :)
cheers
thanks for the help mate,they dont flicker,when the dash light comes on,my drivers side brake light does'nt work,but it only comes on every now and then,it works when the dash warning light stays off.
Re: cheers
thats going to be a dodgy connection to the brake light then. first check the bulb holder for signs of corrosion.
Re: Re: cheers
If its the lights check tour fluid level as when the fluid is low the hand brake light comes on or if one pipe has air in it or is burst you will be driving with ine slightly on all the time sounds odd but thats what was wrong with mine afew weeks ago.
Lew B
5
730
Wayne
W
T
5
426
M
M
398
M
I
842
ian gardner
I
