Originally posted by Evil-Punto
OK, you need to find a permanent live (easy if you have an amp wired into the boot). Wire the live to the back of the switch (lower part with the pads next to it), from the other side of the switch you need to run a wire to 1 terminal of the boot light (shouldn't be too hard to run the wire behind the internal panels), the other terminal need to be wired to a decent earth (any bolt should do OK).
Put your bulb in and thats it job done.
www.puntoforum.co.uk
thanks EVIL I'll try that when the car is back home. even though I and car electrics are as close me and Kylies Mum
Evil-Punto AKA Evilution.
