Ok so my boot ligh doesnt work, no power getting to it, cant find the wiring diagrame to locate the fuse to test that. Can anyone enlighten me to its postion. Cheers.
it cant be hard to find the switch, it must have a little pin sticking out somewhere that will be pushed when the boot closes. maybe its built into the 3 contacts for the wiper and demister
as a quick test use a small wire to the body of the car to see if their is a good earth their. if the earth is disconnected then their wont be a corrent showing because the power wont flow.
(if that makes any sence at all then your a genius.)
Which bit of trims that under?
