General  bolt on carb
moshpit666
Leicester, United Kingdom.
i have had my uno looked at because of a lack of power+power distribution problem been told its most likely the carb and so if i have 2 get anew one shall i just get a K&N bolt on carb?
the car starts up and sounds bad, mainly due to a loose bearing on the cambelt, but when driving the car seems to lack power, (i.e. in second i will put the pedal 2 the floor and the car pulls away but in fits and starts, kinda doesnt get all the power down at once just decides when it wants to go and is as if i am coming on and off the clutch all the time, so my head bobs around in the car!
Smokeme, how would one go about doing this?
So far I'm thinking...
Take off air box and spray carb cleaner/spray in while revving the engine?
Or you could tear the carb apart, loose a few pieces put it back together and find car won´t even start:D . Use the spray then say how it went.;)
car is a 94 L reg 999 fire uno, generally the car is running on low fuel averaging a quater of a tank bc in a student and cant afford to fill up! my uncle is a mechanic so hes guna have a look. thanx 4 all ur help and i will post up when iv had it checked out and fixed!
Finally someone thinks about posting the solution to their problem!!:D
If it's from 1994, it's most likely an injection unit and not a carburettor. Is the car named 1.0 ie or something. Then it's got a Bosch MonoJettronic (SPi) module. It's a hybrid injection / carburettor. Check this first.
Morten.
there is a lack of power when accelerating not an increase,if pumped maybe a better acceleration i will check. will check the spi thing when goes in 4 check up. i posted on here to see if i cud get sum help before i took it in,surely thats what this forum is for? sorry if i have wasted anyones time (smoke me)by posting on here !!!!!
I´m just glad to be able to help, what year is the car and engine size or model if you don´t know.
just ad my car looked at! found out it was the whole single point injection system electronics! will cost me £370 for a whole new system from a scrappy!!!! so i dont av enuf money 2 cover it!!! im in a low position at the mo! cant believe it!
You're not "wasting anyone's time". I think what smokeme meant was that it would be fun to have a few solutions posted as well as the problems! Quite a number of cases go unsolved I think!
We all try to help but it's always good to learn about solutions too for future reference (and me, no sorry I've got no ideas about that SPi)...
-Alex
