General Blue &Me
General Blue &Me
Phlipsy
Liverpool
Hi all, could anyone of you kind people please explain to me where I can find the blue & me on a 21 plate 500L cross. I have tried the back passenger door, no way of getting the casing off, nothing under the back seats, and there are some connectors under the front passenger seat but none look like the pictures of the blue & me unit. Could someone explain this to me like you would ab idiot please.😊
Attached 2 eLearn docs for the post 2017. One on the RHD radio, the other one on the LHD Uconnect system, or how they were naming it at that time ;)
Both contain wiring diagram and component location.
Wrong forum section by the way :)
  • x330 500L MCA2017 - eLearn - Electrical functions - E3570 Integrated radio phone.pdf
  • x330 500L RHD MCA2017 - eLearn - Electrical functions - E3570 Radio.pdf
I can also tell you it's not behind the glove box , however what ive found out from this forum is that they was made in Mexico and Poland, whilst I was checking behind the glove box I found labels and inspection stickers parts labels ect behind the glove box. I also used a mirror to reflect up behind the glove box which also shows makers labels and conformation that the B&M module isn't behind there but im only quoting if its made in Poland , ive checked behind the passenger seat and your right it is very difficult to get them side panels off but I did and was gutted when I seen it wasn't there. Under both seats nothing behind give box nothing only conformation it was made in Poland, because the side Pannal are difficult I'm reluctant to take off the back passenger drivers side panel because it is so difficult. However I come up with an idea. I've bought from ebay a mobile phone endoscopy it's a meter long plugs in to the charging port and was around £6.50 the head or camera head is 5mm wide knowing I can put some of the Pannal out without taking it off I'm hopeful I'll beable to see if its behind the drivers back seat I'm expecting I'm expecting the endoscopy Thursday which you pug in your phone charging port mines a C type they also have mini USB and will as standard USB can be used on mobile or laptop and for £6.50 no brainer that's if its able to see it there I'm 6 leds and a controller for light brightness. Hopefully this helps you as I know your wanting the same answer I want, "were have you put the B&M module location please " goodluck
