Technical  Blue&Me
Technical  Blue&Me
ScarlettTehya
United Kingdom
As I dont have an AUX port on my Fiat 500 would these gadgets work so I'm able to play my own music?
The first one is a bluetooth adapter so it plugs into the USB port and the other end into the AUX port.
The second one is a aux adapter so one end plugs into the USB port and the 3.5mm jack on the bluetooth adapter would plug into the other end.
In a word, no.
You can't stream audio via the USB port on a 2010 Fiat 500. The port is designed to play music in .mp3 format from a windows-formatted USB stick, no more than that.
The best way to play music is to transcode it to .mp3 and put it onto a USB stick. If you do that, you'll be able to use the buttons on the steering wheel to select tracks, and if the files are tagged correctly, you'll get a track description in the MFD.
Alternatively, change the head unit for one with the functionality you want.
