OK, Blue 2 sits there with crumpled front inner wing and somewhat deranged rear slam panel and etc. The running gear is in the process of being sold. I already have another Cinq shell as the basis for project Fiyota (which may be renamed Toyfiat).
But, I wondered, given that the passenger space is pretty much OK, why not spaceframe the thing and pop in a bigger engine? Motors that come to mind are the ubiquitous K series (in 1800 guise): light, cheap (but would need total rebuild),lots of knowledge and tuning parts out there at sane prices, maybe 165bhp in fast road trim) or the 1.8 Turbo VAG lump (replace water pump, heavier lump, packaging an issue with the tub, what, 210bhp or so). Either should propel a Cinq pretty well.........
Here's the more difficult part of the planning (and blagging bits) stage: the project will not use the inner wings from the Cinq, hence it won't use McP struts -- it will use twin wishbones at the front which gives a lot more freedom in terms of where the engine goes and adjustability (essential if it is to handle at all well). Problem is, I need FWD hubs/uprights which will take wishbones -- it may be possible to adapt -- not by welding -- strut type uprights, but a wishbone set up would be a better place to start. Apart from the mini (and a few expensive Hondas and modern Alfas) Any ideas? Quite like the idea of a pushrod set up........
Goes without saying that this is (or will be, if it ever gets started) a very long term project -- there's Blue to finish, then Project Toyfiat, as well as regular work...........
