hi im new to this site but ill post the spec of the gt i have been building
ENGINE
1400 block
wossner forged pistons
arrow rods
ARP rod bolts
ARP main bolts
ARP Head bolts
fully balanced bottom end (inc flywheel, clutch cover)
blue printed
spesso HG
COMP RATIO 9.0:1
HEAD
Fully worked head (port polish etc)
Bronze valve guides
new standard valves
piper valve springs
piper fast road cam (270)
EXHAUST
Evil equal length tubular manifold (ceramic coated in performace white)
Evil 2.5 inch elbow and down pipe (ceramic coated in performace white)
Evil 2.5 inch straight through exhaust two silencers
DTM centre backbox
TURBO
GT2560r (GT28R)
ported and polished turbine housing
ceramic coated in performance white
billet alloy comp wheel
aero nut
custom 3 inch inlet adapter
3 inch inlet pipe ceramic coated
Forge actuator with 1 bar spring
Transmission
fully rebuilt GT box
shot peened gears
new bearings through-out
fully brass synchros (not like standard with carbon in side)
Quaiffe LSD
5 plate ceramatallic sprung paddle plate
new LUK clutch cover
bonalume short shift kit
Electrical
Megasquirt 2 ecu with for 4 bar map sensor
switchable maps
launch control
magnercore 8.5mm HT leads
NGK bcpr7et plugs
440cc injectors
bosche 3.5 bar regulator
open IAT
innovate wideband
AFR Gauze
SUSPENSION
spax coil over kit
eibech camber bolts
front poly-bushes
front lower strut brace
front upper strut brace
BRAKES
BREMBO calipers rebuilt with new seals and pistons
cross drilled discs with ferrodo DS2500 pads
braided lines through out
millers dot4 brake fluid 310 degree boiling point
adjustable compansator valve (got rid of the fiat load valve)
no ABS
rear green stuff pads with crossed and drilled discs
TYRES
Eagle F1 tyres through out
missalaneous
ported inlet
all port matched manifolds
Kent reinforced timing belt
255 lph fuel pump with high flow filter
forge intercooler 57mm boost pipes
mocal oil cooler
airtec turbo water cooler
AEM water methanol injection with progressive controller (for the comp ratio i am using)
turbo smart ebc
hks dumpvalve
saxo power steering pump electrical
fully interior GT3
full respray in blue
seem welded
millers cfs 10w 50 oil
millers gearbox oil
ENGINE
1400 block
arrow rods
ARP rod bolts
ARP main bolts
ARP Head bolts
blue printed
spesso HG
COMP RATIO 9.0:1
HEAD
Bronze valve guides
new standard valves
piper valve springs
EXHAUST
DTM centre backbox
TURBO
GT2560r (GT28R)
aero nut
Transmission
shot peened gears
Quaiffe LSD
Electrical
switchable maps
launch control
NGK bcpr7et plugs
440cc injectors
open IAT
innovate wideband
AFR Gauze
SUSPENSION
spax coil over kit
eibech camber bolts
front poly-bushes
BRAKES
no ABS
TYRES
missalaneous
ported inlet
mocal oil cooler
turbo smart ebc
hks dumpvalve
fully interior GT3
seem welded
millers gearbox oil
