Technical better wiring diagram marea 2.0-147hp
predrag
belgrade, Yugoslavia.
K20-Fuel pump relay
F-Fuse
K46-
Engine control relay
K153-Camshaft position (CMP)actuator relay
Y99-Idle air control (IAC) valve
Y104-Evaporative emission (EVAP) canister purge valve
Y3-Injector
T1-Ignition coil
H63-Tachometer
B33-Vehicle speed sensor (VSS)
Y81-Camshaft position (CMP) actuator
M12-Fuel pump
A35-Engine control module (ECM)
S39-Inertia fuel shut-off (IFS) swich
B72-Heated oxygen sensor (HO2S)
B30-Mass air flow (MAF) sensor
B24-Engine coolant temperature (ECT) sensor
B25-Intake air temperature (IAT) sensor
B69-Knock sensor (KS)
B147-Throttle position (TP) sensor
B132-Camshaft position (CMP) sensor
X1-Data link connector (DLC)
K17-AC relay
S341-AC refrigerant pressure swich
X88-AC connector
A162-Immobilizer control module
B54,B75-Engine speed (RPM) sensor
