I had a spot of bother with the battery terminals on my car, so I've come up with a replacement plan, I'm partway there so thought I'd share. I've bought a set of mutant battery terminals used usually for in car entertainment purposes, these replace the positive and negative terminals. That's it on the neg side, just snipped off the stock cable ends and off we go. On positive side I've got 4 cables. The starter cable is unfused straight from the new battery terminal, then I have 3 cables fused in the branch distribution unit. A 150 amp anl fuse in a sealed unit, a 60 amp and a 70 amp agu fused pair of units take care of the rest. I've matched fuses to the originals, and I have managed to rid myself of the horrid original fiat wiring. The starter motor now spins more easily, and kangarooing from stationary is gone! Well chuffed.
Have pit back fiat positive terminal for now as I need to source some seriously thick positive cable for the 150 amp supply! I'm also going to turn the battery around so terminals are at the front if the bay to neaten the whole lot ups little. The mutant battery terminals have an integrated voltmeter in which will look a bit weird upside down!
