Hi to all,
Details of vehicle.
Fiat Ducato 2.5 non turbo 1992 Weinsberg camper.
Details of the problem, and actions taken.
After doing the regular DOE (MOT), failed a small hole on the cill under drivers
door.
Fabricated a portion of the cill, and ready to migweld into place.
Disconnected battery, and disconnected all cables from alternator.
Welded part into place, then dressed welds and completed with primer
and paint.
Connected up alternator, then connected the battery.
Then wanted to start up camper, but noticed the battery (charging light)
ON!!! The ignition was OFF.
Suspected the alternator diodes, but the alternator was disconnected
before I proceeded with the welding. Decided to get alternator checked
anyway. Brought it to a alternator specialist in town.He checked and found
it was working 100%
I asked for his opinion on what the problem might be, and his belief was
that the fault lay elsewhere but nothing wrong with the alternator.
Refitted alternator, and connected leads, and connected up the battery.
Ignition is OFF................battery light still on. I then disconnected thin
wire from the alternator, the battery light went out. Reconnected it and
the light came back on again.
Am I correct in saying that I have 12 volts on the cable before connecting
to the alternator. Is this correct I wonder. Should the 12 volts come from
the alternator to the battery lamp, and the otherside of the lamp down to
earth. Or should the cable be live, and then receive its earth from the
alternator to complete the circuit. I'm not sure to be honest.
I have no wiring diagrams to go by, but the circuit should be much like
any other I suppose.
Any suggestions or help would be greatly appreciated.
Thanks a million.
John.
Details of vehicle.
door.
and paint.
it was working 100%
Thanks a million.
John.
