Technical  Battery Drain
stilo 1.2. 03. replaced battery as kept having to jump start every morning. found out that even with new battery had to do this as well. Removed the earth cable and cleaned that up and checked with earth removed from battery and conected multimeter to both and showed 0.2 amp which i have found is fine. i removed the fuse for the radio from fusebox in a hope that might help. after leaving car overnight an late into the afternoon car started no problem. now my issue is how do i find where the drain is on the radio circuit or has anybody else had this. it has the standard radio/cd player in car.
hope someone can help.
thanks
Start off with what battery you got! I will always credit Shadeyman for pushing for bigger and more powerful batteries for all Stilo's, he is totally right. So what have you got? :)
