L lescourlis New member Joined Sep 25, 2014 Messages 4 Points 1 Oct 6, 2014 #1 Wipers not working however washer works. Fuse ok and wire connections appear to be ok. Anyone had same problem?
HP I was only doing 80... Parked in the garage Written a guide Joined Mar 22, 2002 Messages 13,428 Points 2,034 Location North East Oct 6, 2014 #2 Check the ignition switch. Mine threw a wobbler before and the fan and wipers stopped working - wiggling the ignition key got them going again.
OP OP L lescourlis New member Joined Sep 25, 2014 Messages 4 Points 1 Oct 6, 2014 #3 Thanks for that ,I'll try it and let you know if it works.
OP OP L lescourlis New member Joined Sep 25, 2014 Messages 4 Points 1 Oct 6, 2014 #4 Still not working. Thanks anyway
Dave-M Patron member Parked in the garage Joined Dec 16, 2006 Messages 646 Points 223 Location North West Oct 6, 2014 #5 The wiper mechanism is known for seizing up, this will burn out the motor. Before you try again check the mechanical linkages.
OP OP L lescourlis New member Joined Sep 25, 2014 Messages 4 Points 1 Oct 7, 2014 #6 Hi have checked out all the linkages and all are well greased; Its looking like I will have to bite the bullet and replace the motor. Thanks
nixbarchetta New member Joined Apr 29, 2007 Messages 58 Points 17 Location Macclesfield Oct 21, 2014 #7 I have a motor I need to sell on. My linkages seized but motor still good, I had to buy the whole thing though to get the bits I needed! It's off a 98 LE, if that's any use to you PM me with an offer
