So on to the next issue....; fuel stank.
Questions:
1) When the tank is full and without any tank pressure build-up, there is a leak around No. 14 (see pic), part No. 46755835. Do you have any suggestions for a solution, eg is there any sense in trying to apply a liquid seal (it needs to hold against tank pressure build-up (and down))?
2) If yes, any recommendations on what product to choose?
Background:
On the one and only longer drive with the barchetta -95, we filled up and drove for 5.5 hrs in pouring rain with the soft top up (oh yes, the soft top leaks like a sieve when standing still (am waiting for new soft top silicone gaskets)), we got dizzy from fuel fumes (and perhaps the noise).
Thanks to this forum I have gotten the fuel tank panel/cover/bulkhead out.
The fuel tank area has a lot of crud in it. I have yet to clean it out, but was keen to look for leaks, so I filled up the tank. The first leak I have located (so far) is around number 14 "Seal gasket" OE 46755835 (see pic). What material is is? I don't yet know if the leak is between the tank and 14 and/or 11 the filler tube. I suspect the filler tube is a replacement part as it looks newer, and has a hose clamp mounted on it at the connection to No. 14. To me if No. 14 is made out of rubber, a hose clamp would make little sense. I have not yet taken the connection apart, but it looks like the filler tube is clamped over the No. 14 seal gasket lip.
On the original mount, how is the connection pressure resistant (between parts 11-14-1)? Is there any description/picture available on how these three parts should be mounted (w/wo clamps and/or sealing compounds)?
Thanks for the read and any feedback!
T
Questions:
Background:
T
