Technical Axial rod (tie rod end) identification help
Orestis
Hello everyone!
I have a 2013 Bravo Multiair which seems to need a front right axial rod. However, it appears that the previous owner had replaced the steering rack with one from a different car model, so instead of a Male - to - female rod, my car has a male - to - male one. The writing on the rod seems to be MOOG 623 16085 (though it's also possible that the last two numbers are 9 and 6). The length is 31.5cm and the thread lengths are about 2 and 5cm. I'm adding the photos they've sent me. Could you help me identify the part?
Thanks!
  • 0-02-05-78f914bee1de3c4b9416ef98eb5280744b68f1fa9b32697002c17d270d80d99e_1ef50f2f2dbef3.jpg
  • 0-02-05-b04e3386d5a85cb56dd84f3de3880eaeaa9db0684fe03f2b604f383733460326_1ef50f2f2d881a.jpg
  • 0-02-05-676558ad340d2ac975e2ded384603a61006f6f81d1f803ba62f13a6f4d1c5d72_1e3a6d99a8f5f8.jpg
  • 0-02-05-de072d0d5a44403adb7837a4a760c16ab00938abaa8287204d0e26023288cdc3_1e3a6d99a809b4.jpg
Hello,
The last digit is definitely a 5, as you have a 6 and you can see that the stamping is completely different. As 9 is a reversed 6, I would also assume the 4th digit in the second segment is not a 9. But possibly could be a 3, which is the most similar to 8.
I did a search on moog website with both combinations (623 16085 and 623 16035), but with no luck.
But searching with 16035 gave some interesting results :) Check this part number: OP-AX-4160
It's a little bit shorter (306,5 mm), but I think a tape mesure is not a proper tool for mesuring such things.
According to amazon it suits Opels/Vauxhalls, but the moog website states several FIATs / Alfas:
And the part looks similar on Amazon :)
Thanks for making the effort, @the green vanper! I just got off the phone with my parts dealer. He had already taken this part to the garage, but unfortunately, apart from it being indeed a bit shorter, it also has some kind of a flange on the shorter thread, which prevents it from being completely screwed in. So, I guess the search continues. As for the Amazon image, it appears to be a generic image, and not one of the specific part.
I'd contact Moog directly via their website. It's the easiest way to get a 100% accurate answer.
Yes, I did that and I'm waiting for a reply. I just thought I'd give it a shot, in case somebody over here had an idea. Thanks again, though!
I just thought I'd post an update of what happened, so that the thread has a closure:
After looking through a bunch of catalogues and exchanging a few e-mails with gurusoncall.tech, to whom I was referred by Moog, I got the information that the number on the rood is simply a LOT number, and not the part number. So, there was no other options but to work with the measurements I have. This led me to a possible candidate, which was SU-AX-2866. As the "SU" in front suggests, this is a part for SUBARU!
In the end, I got a compatible part from a SUBARU parts dealer, which fitted like a glove!
Now, the question is: "What on earth is a SUBARU steering system doing in my Bravo"?
